2kwik4u
- Buffalo, NY
So I removed the tower, ran some wires, and moved the battery this weekend. See HERE for the pics/details on that.
In order to run the soundbar wires through the tower, I had to cut off the fuse holder from the 12ga power, and the eyelet from the 12ga ground. Once ran I had to reconnect these ends, which meant a splice.
I purchased THESE solder/heatshrink combo devices, but clearly have no idea how to use them. I took the ends of the wires, stripped them back and pushed them togethor, then "twisted" them with my finger and thumb to get the "wild hairs" laid down. I then hit them with a heat gun until it looked like they were going to catch fire. The solder never melted, and the connection was weak at best. Here's what it looked like
SO, I ripped that apart, and used a standard butt connector, crimpers, heat shrink, and then electrical tape. It looks like hammered dog turds to be honest, and I'm not really happy with it.
This is with just the butt connector. Feels like a strong structural (pull test) connection.
The heat shrink had to be big enough to get over the obscene looking butt connector, so it didn't shrink all the way.
So I wrapped the snot out of it with electrical tape. Hopefully this will make it somewhat water resistant.
I wasn't really happy with that connection, so I dug out the soldering iron, solder, and went to work on the ground wire. It turned out better, but not great (I couldn't find the flux, so it didn't wick worth a crap). I forgot to take a picture of that connection. Overall I'm not really happy with either connection. It's well fused, and it appears to work just fine, but the connections looks bad. Am I over thinking this?
Secondarily, how in the dang heck are those solder filled, heat shrink combo connections supposed to work?
