Luke Lapham
- SX
I have a 2010 242 limited and I just got back from Bimini on vacation a few months ago and the boat has performed great, however the other day we took it out and when we got back and I pull it on the lift the port engine would fire then stall as if it wasn’t getting gas. Did the usual tests and found she has spark, compression but the fuel pump is not turning on. So to check off what it could be I swapped fuel sending units, no change, I swapped relays no change and I swapped ecm and no change, however even with the swaps the starboard ran fine with each swap of each part. Sooo brings me to my last test which I found that the running engine is getting 12.6 volts on the plug that hooks to the fuel sending unit... the engine that is not running only getting 10.4 volts to the fuel sending unit. Obviously that is not enough to activate the pump, but I don’t know what that means ... wether a new wiring harness or I have a ground issue somewhere and I don’t know how to fi
