Master-Spud
Jetboaters Commander
- Plamondon, Alberta, Canada
- Nautique
- Other
So need some advice, having some battery issues and I can't decide if it's the battery switch or the ACR or what the issue is.
Boat has a an board charger that is connected to both batteries, always plugged in when at home. Boat is equipped with dual batteries (one starter, one house running the stereo equipment) also has a dual battery switch and an ACR.
Now the issue, was on the water and the starting battery is dead, think that's weird, reads low voltage on the helm, flip the switch to combine and off I go, good voltage on the helm gauges. So i get to shore and decide to pull the house battery out of the boat cause maybe my on-board charger wasn't working. Throw it on a different charge, reads 100%... hmmm weird... grab the other battery from the boat thinking maybe I'm crazy and grabbed the wrong battery, throw it on the charge... reads 100%. Reconnect only the starter battery, throw the battery switch to the normal position, low voltage on the helm! For fun put the switch to combined (no house battery connected at all) and voltage jumps up to normal?!? WTF!!!
So now I'm confused, been basically having to run with the switch to combined or I'm unable to run the boat but it all really doesn't make sense to me.
Is the switch toast? seems like a pretty rugged part and not much to it but it's the only thing that makes sense to me, unless I'm missing something.
