Hey guys, having a little issue. 07 ar 230 engines are fine but nothing else works. no stereo, fan, lights, bilge where are the fuses at? Any other ideas?
Could not find a fuse but I checked the 2 house batteries and both registered 6 volts. starting battery 12 volts. Took them to advance and they said the bats were shot. I had the 2 batteries wired together and on a tender. both went bad, any suggestions on why? one was a yellow top one was a blue top.
I would think even with low batteries you would still get a light or some radio function,
I have no idea about battery wiring since I only have a single stock battery,
I will post pictures of mine and the fuse screwed to the wall, it could be that whoever installed your second battery took the accessory fuse out although I don't know why,
Nothing lit up. not even the switch lights. I installed the 2nd and 3rd batteries myself along with the ACR and switch several years ago. I have never had an issue till last weekend.
