Jeremy
- Exciter
Hey guys, I'm looking for some advice. I have a 98 Yamaha exciter 270hp twin. I am getting plenty of spark out of the left engine and it cranks up no problem. The right engine loses spark right after I turn the key. It continues to crank but will not fire up. Sometimes I turn the key and it won't even make a sound at all. I took it to two different shops and neither one knew what the problem is. Sometimes if I run the left motor for a few mins on the water then the right motor will start up. Occasionally the right motor will die on me when I'm just cruising. Any advice would be great.
