electronic throttle
Shady
Dayton, TN
What year did the 240 start using the electronic throttle? Reading online i have saw various years reported. I also searched on here and didnt see.
So, I'm no authority on this topic but I had a clue on where to look. Hydrophase makes the Ridesteady system for all Yamaha jet boat models equip with a accelerator position sensor (APS). On non E-series models, this sensor converts the position of the mechanical throttle at the helm into the electronic signal the ECU manages. I'm not sure how it's all controlled on the E-series models. From Hydrophase's website it lists the compatible model years for the 240 & 242 as being 2010-current. So that should be your answer.
Mechanical or Yamaha Jet Boat Throttle? | HYDROPHASE LLC
If you mean electronic throttle control at the engine, where the throttle is controlled by APS, the answer above is correct. These boats may still have a control/analog/physical cable to control the signal from the helm.
If you mean electronic throttle controls at the helm / drive by wire, the answer is different. Only certain high end models have that.
Can you clarify what you mean by electronic throttle?
2015+ all 242 E-series and 242X.
In 2010 Yamaha started using 1.8L engines with a TPS/APS. Prior years using 1.1L MR-1's have no TPS and throttle cable from the helm connects directly to the throttle body, with no electronic interface. If you mean E-series, electronic controls than @swatski has the answer.
I was referring ot the fly by wire. Sorry i wasnt clear enough, i was unaware of the differences which I think I s why I couldn’t find my answer. I see it was answered thanks all
