ripler
- Just south of Pittsburgh
- MasterCraft
- Other
Even if the battery is showing that it is fully charged on a multimeter it can still be bad, you can have an auto parts store do a test on them. When I had my Yamaha I had a battery that showed fully charged on a multimeter and it actually started the boat, but it had a few bad cells in it. When the boats charging system tried to charge it the regulator/rectifier on both motors got so hot that it melted a few pins on the connector that plugged into the regulator/rectifier. You want to talk about a troubleshooting nightmare. I ran the same setup that you have in my Yamaha for the 10 years that I had it and had zero issues with it, my philosophy is to keep it simple, a DVSR just adds another failure point.
