Pedro dejesus
- Limited S
Hello A Team.... I have a 242 with the typical two battery set up. I have encountered a problem where all of a sudden the boat will only turn on(crank) when the parallel switch is on. Both batteries are fully charged and have been load tested. When both engines are on and I disengage the parallel switch(off) the boat goes into protect mode. I am thinking that the switch has gone bad. Any suggestions?
