VitaminSea
Jetboaters Commander
- Central FL
- SX
Hello Braintrust - In my waverunner, I am replacing the engine anode and I am having one heck of a time, so I am reaching out for some tips. I have purchased the replacement kit (Anode Cover, Gasket & Anode) as pictured below. I share this, as I am indifferent to how the existing anode cover looks post the removal (as I have already put quite a few gouges in it from my pliers).
My waverunner has the 1.8L motor for reference. I was able to remove the bolt that holds the assembly in place on the side of the engine block - that in of its self was a pain due to the tight clearance, and minimal range of motion for any type of wrench. So open to suggestions here for when it’s time to reassemble if there’s a more favorable tool here than a 12MM box wrench (my ratcheting wrench’s head was too large to fit in the area).
Now to the anode assembly, over time I have been able to work it “free” so that it can pivot/rotate clockwise/counter-clock wise a few degrees in each direction, however I have NOT been successful in removing it from the block. I have tried using different screw drivers and small pry devices to extract the assembly, but it hasn’t yielding much in the way of results (I may have been able to extract the anode assembly ~1mm from the block). I have been spraying the anode with Free All Penetrating Oil (pictured below), and I believe this is what allowed me to free the assembly so that it would rotate some (initially it was just stuck).
From looking at the assembly, I believe what’s causing it to hang up is the rubber gasket. I could totally be wrong here, but it appears swollen, as it was partially sticking out of the block (here’s a photo from when I was working the bolt out).
TL/DR - What tips/tricks can one use to extract the engine anode from the block if liberally spraying with a penetrating oil, grabbing with Channel Lock pliers, and attempting to pry have been largely unsuccessful?
Thanks in advance!
Thanks in advance!
