tim2808
- Spring Hill, TN
Has anyone ever had an issue with the engine cutting off after hitting the water after big waves? My 2013 AR192 has started cutting off everytime the boat splashes back down after hitting a decent size wave. The dash board stuff all stays on. If I put it back in neutral I can start it back up and take off. Sometime before the boat even comes to a stop.
The radio is on another battery and never cuts off either. Both battery’s are grounded together.
It’s almost like the lanyard emergency cut off is pulled but it’s still in place and looks fine. And works. But I haven’t replaced it.
Anyone have other ideas? Or hopefully a common problem that I can investigate?
