gmtech16450yz
Jetboaters Commander
- SF Bay Area
- Limited S
Ok I'm really not liking this NMEA 2000 BS. Why didn't they just use standard automotive OBD2 protocols? I've tried all my automotive diagnostic hardware and software including generic OBD2 readers, Yamaha's YDS1, and all the tuning programs I have just trying to read ANYTHING from the data lines in this boat. No luck. I can't even read trouble codes.
I can't even get my Simrad GO9 to read any data off the CAN network. I set up an NMEA 2000 network for the Simrad and also tried connecting it directly to the Yamaha network. It will show that it's connected to the network, but it doesn't get any data whatsoever. I'm assuming the Simrad doesn't have the correct software to read the new Yamaha's, or there's something different about the '17 1.8 CARB version of the Yamaha that's keeping it from picking up the data off the network.
So here's my question... Has anyone been able to connect to any of the newer ('15-'17) boats and successfully read engine data and/or codes? I'd like to be able to tune these engines, but I can't even get past the data reading mode much less writing mode. I know about Maptuner X, but I was quoted around $2k to be able to read and modify the ECM's on both engines. $2k??? Are they kidding? The best tuning software and hardware made for automotive applications is around $500 and it costs $100 per vehicle to have pretty much total control over hundreds of ECM tables. I wouldn't mind spending even $1k to read and modify these two engines, but I think the Maptuner X software is pretty crappy as far as what you can even do anyway. Paying $2k to only be able to change basic timing and fuel mixtures is ridiculous. Same with YDS2.0 even if I could buy it. It looks like it would be around $2k also, and all you can do is read, no tuning possibilities there. I'm not interested in spending $2k to just read codes.
Anyone have any experience or thoughts? My radical thought is to pull these Yamaha engines out and put in a couple of GM LNF turbo 4 engines. Direct Injection and variable cams that can easily be tuned to a super dependable 500 crank hp each. Hmmm. 1000hp Yamaha 212 Limited S? The sad part is it would probably only do 60mph! I'm not ready to go crazy like that, but it sure would be nice to be able to clear codes and see simple engine data with what I already have. So far I'm running blind.
