Bryan Chandler
- 242 Limited S E-Series
Hello everyone,
I have a 2013 Yamaha ar 242. Both of my engines start and run well on its own but when I go to start the second one the first one started will run rough and throw a check engine code. It does not matter which sequence I start them in it always seems as if the second one started starves the first one long enough to throw a code and put it in limp mode.
What I have done so far:
I put fuel cleaner and a mix that removes water and ran a half a tank through.
I then changed the batteries
Neither of these worked. Seems like it would be something that goes to both engines.
Any ideas?
Thank you all
Any ideas?
Thank you all
