Thomas Fossett
- SX
OK all, brand new to the forum as I have not had any problems. Since that issue has been remedied, I am now here.
The issue: The Port motor will not even sound the pre-start beep. I switched the harness on the key switch, Switch is good. Starboard motor starts right up. The starboard engine runs great at all times (Except now that I said that out loud, I am most likely screwed.) The main cables are clean and in great condition. The fuses are good. I am not sure where the neutral safety switch is, so I can't check that. The safety lanyard is fine. The rear pumps clean out hatch switches are good.
Anyone know the next step?
Besides turning it into a reef?
