Dave Rintel
- SX
If this has been posted before please point me to the thread. I started the day with a blown 20 amp fuse and the right engine wouldn't start. I replaced the fuse and everything seemed fine until about an hour of running. Then the engine wouldn't idle well. That progressed to not starting....well kind of. It would start and run as long as I held the key in "start" (as best as I could tell as I didn't want to leave it there for more than a couple of seconds). The fuse is still good. I pull the boat out of the water and flush the left engine. Then I habitually flushed the right and realized it was now running fine. Back in the water it goes. Right engine won't run, just some sputtering. Out we go again. Runs fine. Thoughts?
