Eagles@1
- Scarab
- Other
I recently purchased a 2016 Scarab 165 H.O with 12 hours. Everything worked a+ until this weekend (now at 22 hours) when I experienced power lost and eventual stall on the river. Engine starts but stalls after 30-40 seconds. I removed the spark plugs once I was managed to get recovered from the water and the middle of the 3 plugs was darker. I then replaced the 3 spark plugs, checked that the gaps on the new DCPR8E plugs were within brp specification (measured 0.30) and still no go. I'm thinking maybe the coil on the center cylinder plug that was darker is faulty but I don't know how to check if that is the issue other than seeing if the plug sparks when the engine cranks.
Any help would be greatly appreciated!
