AZ Native
- Phoenix, Arizona 85044
- Limited S
So I just spent the last hour and half searching the threads to find something on my issue with no luck. So here goes:
I’m really frustrated with the intermittent port engine performance on my 2013 242 Limited. Max RPM on the Starboard engine can hit 7,500 at a lake elevation of about 1,300 feet. The port engine can only produce 6,000 RPM. Yes the cables are properly adjusted, yes the oil, plugs and air filters are fine and no I don’t have a cavitation issue. Here’s the kicker, when I started out yesterday heading across the lake the port engine suddenly jumped up to about 7,500 RPM WOT (joyous moment) matching beautifully the Starboard engine, for a long 15 minute run across the lake hitting 45 MPH with 4 big men in the boat. After stoping for lunch, the rest of the day I could only get 5,900 RPM out of the Port engine for max 30 MPH, although Starboard still will run 7,500 WOT. I do know that the throttle cables connect to an electronic sending unit that somehow manages the EFI. It’s like whatever is making decisions for the fuel rail on that engine is confused. I know nothing about the EFI and Electronics of the ECU but I’m hoping someone can weigh in on this mystery saving me an expensive and time consuming visit to a shop.
