JC Chile
Problem: the engine runs fine, and RPM goes up but the propel is not providing propulsion. It seems like a gear issue…where should I start?
I have a single engine 2018 AR195, I bought it with about 80 engine hours. Shipped home (Chile in South America) and on my second day on the lake, it got a sky rope wrapped around the shaft (I know….). I didn’t realize about it, so I sucked the rope all the way until the engine stalled by itself.
I was pulled to the dock and took the boat out of the water and took all the rope out of the shaft.
I launched the boat back in the water, the engine seams to run perfect but the power is not being transfer to the propeller. Making several tests in one or 2 timescthe propel gain trust and the boat worked normally. But most of the tests I did, the engine RPMs goes up but no trust on the propeller.
I removed the propel and shaft out of the housing to make sure that the propeller and the shaft are clean and in good conditions and everything seems to be fine.
I detached thee shaft to check the treads threads thinking that the torque made by the engine and the sucked rope could have damaged it but it looks fine.
Not sure what else could be causing this problem of lack of propulsion from the jet when the engine is accelerating well, and the revs are going up but no trust in the propeller.
Need the community’s help!
