David Martin
- Punta Gorda
- SX
Hey Guys.... showing my temp gage install, I'm new to Jet boats so I have a few questions as well. I have 30 years experience on Merc I/O's. Hear is the gage at Amazon Amazon.com: GlowShift 10 Color Digital 300 F Dual Temperature Gauge Kit - for Water, Oil, Transmission Temp - Includes Electronic Sensors - 2 Multi-Color LED Displays - Tinted Lens - 2-1/16" (52mm): Industrial & Scientific =UTF8&psc=1. the brass is Amazon as well but you can do the same thing at HD or Lowes as well.
I first installed the 1/2 inch brass T 1/2 inch barbed and 1/2 to 3/8 NPT reducer for the 3/8 NPT temp sensors in the pissers lines that exit the boat.
I installed mine in the engine bay. I ran the wires up the tunnel in the gas tank compartment to the storage behind the helm...... the steering cables use this chase.
I did have to add wire extensions to the gage factory harness, I just used bullet connectors and 18GA wire. I tested the gage before I drilled any holes in the dash.
Hears my question what Temp and what thermostat do 1.8 engines run...... I know they can't run as cool as the pisser lines. Hear is my testing so far......82 air temp hear in FL water temp 76 degrees. Engine Start 77 degrees claimed to 87 degrees on the 35min run out to the bay from my lift using no wake speed at 2000rpm setting. Putting her on plane 5000rpm 25 mph she dropped to 84 for 20 min. Dropping off plane to photograph a large pod of Dolphin she shot to 104 at low wake as soon as I went back up to 25mph she dropped to 87 and held steady for the next 20 min to the fuel dock.
We stopped on our way back to test the box anchor that I found on this site and it held great in 1 1/2 ft seas on Charlotte Bay. We spent 1 hour at anchor eating lunch, on start up the heat soak engines recorded the highest temp 122 and fell back to 88 after a few min on plane at 25mph 5000 rpm. I did notice coming back Port engine was 2 degrees hotter than Starboard and Port was running 200rpm out of sync. After 200rpm change the temp came back into sync. Sweet more info the better. At lease I have a good starting point on engine temp with only 60 hours on the meter.
