Engine won't crank. Hear clicking sound and wonder if i have a bad relay
lukan734
Engine wont start. Hearing clicking noise when key turn. Ar190 2023
Try jumping it at the solenoid.
I upload a video wonder if you see it, i'm new to the forum
Your boat is fairly new, I bet you have a dead battery. Charge the battery and make sure the connections are proper and tight.
I'd start with the battery, make sure it produces at least 12 volts, ideally 12.5+. If the battery is good, check all your connections to the battery. If that doesn't work, jump the solenoid as @Acard7 suggests. Usually a clicking sound is a bad solenoid in my experience but it's hard to believe the solenoid is bad on a new boat
You should test solenoid I use a remote starter switch.............Some do a screw driver across the 2 bolts to turn over the started I just hate the arching sparks like I welding something. If engine turns over using remote then starter and solenoid are fine......move on to relay and loose or corroded wires both could cause a no turn over/clicking problem.........I always look for a bad ground first boats have this problem most often. Also look at all contacts on the battery switch. A bad ground or positive wire cant handle the 100amp the starting is asking for...... so it clicks.
A bad starter relay that is bad cant hold in.......... so it clicks like others have said to.
