Engine won't start but does turn over (sort of)
Rick Rousseau
Merritt Island, FL
Boat is a 2014 SX190, when I turn the key, the starter turns the motor a couple times but does not fire. I checked the batteries and both were bad so I replaced them. Still the same result, turn the key and it turns over a two or three times but then stops each time I turn the key. I'm wondering if there might be corrosion on the starter connection terminal, or maybe a bad pump ring binding the impeller? Any other suggestions?
***UPDATE*** It was the starter connection. I found the cable running to the top of the starter, wiggled it back and forth (it wasn't loose, but wasn't torqued down either) and she started right up,
Glad you found it okay. That one had me stumped.
I posted this while I was looking at the parts diagrams to get a look at the starter. Found where the starter was hidden and went back out the boat, wiggled the connection and solved the problem. If only they were all this easy.
I have the same problem but with only one engine. I'm thinking that your fix was for both engines to start. Any suggestions?
Mine (SX190) only has one motor. This problem came back and turned out to be the impeller housing had swollen and was preventing the impeller from turning.
That means changing out the wear ring. Also check your impeller for damage. You may feel rolled over edges on the impeller.
Thank you- I will check this out today.
Yes, I'm changing out both wear ring and the impeller.
  • Like
Reactions: Gym
I understand, from a previous poster, that Riva makes a solid stainless steel component wear ring that won't suffer from galvanic corrosion. You may want to check that out.
I'm having the same issue. Mine is a 2013 ar190. Is this similar to what your entire sounded like when trying to start?
I had absolutely no issues last season and when I ran the boat last prior to my winterizing it. However I went to just it last week for the first time and no luck at all getting it to start.
