Engines will not fire -- U0300 Fault Codes (FIX)
dandwms
West Linn OR
Scarab
I spent 3 hours out on the river trying to figure why my motors wouldn't fire. They would both turn over but not fire. I found the U0300 codes as faults in Medallion but had no clue what it meant then found a post in Chapparal/Vortex section. It works with all ViperII Medallion. This happens when the security connection can't connect to the ECM. These instructions re-pair it.
Followed the instructions and it fired. Amazing! Didn't have to pay for a tow!
Here is the attachment. Compliments of Micah from the Chapparal/Vortex FB page.
I spent 3 hours out on the river trying to figure why my motors wouldn't fire. They would both turn over but not fire. I found the U0300 codes as faults in Medallion but had no clue what it meant then found a post in Chapparal/Vortex section. It works with all ViperII Medallion. This happens when the security connection cants connect to the ECM. These instructions re-pair it.
These instructions are complements of Micah on the Chaparral FB page. Really a good guy...
Hello- I am new to the forum and had my wife and kids out on the water yesterday and the engines would not start after running great all day. I did some research and found this awesome forum. I had both engines show fault codes of : u0300. Looks like a security handshake
Issue with ecu and medallion in stricken t cluster. I’m dropping off at dealer to fix. I printed out Michas instructions to fix as this is above my comfort level. My question is will the dealer simply update the computer system or will I need new parts. I have a 2018 vrx with twin 200 hp rotax engines with only 90 hours.
should I get the plugs changed also when it’s in shop? We love the boat
Changing plugs, oil and oil filter is always the best option if you don't know when it was done last. If you have a shop do it make sure they reset the hour counters.
I've had the same error message and and followed Micha's instruction. It worked great! No issues.
Final note: Make sure your batteries are fully charged. Never let them get low. Doing so causes many faults that are maddening. Ask me how I know. :banghead::banghead:
Be safe out there and have fun!
Thank you so ouch for your help.
Have a great day and thanks again ??
nick
