Chuck B
- LX
Hi everone, new to the site.
Have a 2003 LX210 with the lst1200AB engines.
starboard engine was bogging down
comp tested both engines both have 122 to 125 all cylinders
pulled the spark plugs cleaned and re-gapped
on the ramp on the trailer Starboard engine at 4500 fluctuates to 3,000 give it a little throttle and will jump to 5000 then fluctuate, it will run at 5500 like it is up against a governor and will not fluctuate.
the port engine will only run at 5200 in this condition, however there seems to be power to the boat, in nuetral whereas the starboard engine does not try to move the boat.
on the starboard engine I am getting a popping sound in the aft carb when bringing off idle, i am getting good spark to that cylinder though.
my question and looking for input, could the couple slipping, if it is be causing the erratic RPMS, or would 1 dirty carb do all of this
thanks in advance
thanks in advance
