EvaPad “SeaDek” DIY
1BadTundra
212X
I picked up a 5’ roll of AMAZON special EvaFoam pad. I cut it with a razor knife, then used my router for the edging. Is it perfect, no. Was it $100 per pad, hell no!!! $25 well spent, what y’all think? It’s stone grey over blue camo… IMG_2569.jpegIMG_2568.jpegIMG_2567.jpeg
Thanks, I'm pretty shaky with my router LoL, but I figured I'd give it a shot. I couldn't drop $80-$100 on just a pad for these.
image of router setup please.
What router bit? wouldn't be too hard to build a guide for a perfect cut
It was a 1/2" flat with a 40 degree bevel on the side. I used a guide on the straight sections, on the curves I freehanded.
@1BadTundra , this popped up on the list of similar threads, so I was rereading it.
Was the sheet of foam already done with the lines/seams, and you just had to trim it to width and match the edge lines to the interior (or field portion)? Hopefully that makes sense, I don't know how to describe what I'm trying to say better than that right now ?
That's nice work, regardless, considering how much they want for just one of those cooler toppers. I bet that whole sheet cost less than one topper!
Free hand!!!???
That was awesome, the one time I tried free hand with a router it felt I was hearding squirrels.
Respect.
Also, full size router, or trim router?
If someone has a 3
Free hand!!!???
Respect.
The cordless trim routers that are available nowadays are better, and feel more controllable, but you aren't lying about that being a difficult job to freehand! Props for attempting it, had to be some pucker factor with those corners!
If someone has a 3
