CALP1
- SX
I did buy it in 2004 new and boating on salt water only, it has about 400hrs. Never had a problem with this boat, but always have done the flushing with Salt Away which I recommend for all salty dogs out there.
At picture attached I have to check the Exhaust Joint Seal (17), because it could have failed and water is getting into oil by exhaust valve, at the same time I will check the pipe condition also.(water lines are clear but pisser is not working properly)
After checking and probably changing it I will do a water test and check for water on oil if water is still there then I will go to check the engine head but the pipes are the first step.
The attached picture is from ny boat service manual of which I did buy many years ago but the manual does bot specify or may be I am not reading it correctly, if I have to remove the engine before removing the pipes or I can remove the pipes without removing the engine.
So this is the question for anyone on this forum that may know.
Appreciate the help
Appreciate the help
