shibumi
- 242 Limited S E-Series
Have any of you used one of those expandable hoses for flushing?
I need about 100' of hose to (easily) wash and flush the boat. I was considering one of those expanding hoses because they're very lightweight and compact after use.
My initial pause was that, in order to expand, they have a much smaller internal diameter (using water pressure to expand the hose). I thought that smaller diameter would impede flushing of the engine - not enough water.
BUT - then, duh, the adaptors that go on the hose to plug into the flushing port have an even smaller diameter - sooooooo it SHOULD be OK to use - shouldn't it?
