bronze_10
- Raleigh / Wake Forest Area..
- SX
I am replacing my scupper.... in gaining access I had to remove to rubber tube that goes between the jet and the clean out plug in order to get the water box moved out of the way.... the question is.. that rubber hose was covered in a thick sealant on the bottom next to the pump.... I would assume u replace that sealant when you reinstall.... is 5200 normally used or is that too strong? I would not think it is a part that will come on and off much...
