d_coyne1984
- Chanhassen, MN
- Other
- Other
I figured out that most of the noise from my boat is coming from the swim platform area. As has been proven time and time again, mass loading does very little to eliminate that noise so I went the other way and used open cell foam in a very unprofessional looking install throughout the swim platform area. The rear of the boat is acting like a drum and the noise resonates back there like crazy. What do drummers do to tame the resonance in a kick drum? They stuff a soft fluffy pillow in there to dampen the heads and slow the sound waves. It made a fairly big difference. I am now under the belief that if I fill up the open voids in the boat as much as possible, that there will be little airspace left for which the sound can resonate through.
So here is my new thought: Before I put my seadek down, I am thinking I can drill a couple small holes, and pump it full of expanding foam. My main area of focus is the area in front of the floor locker where there is a fair amount of dead space on the 192. I would leave the rear of the boat alone so as not to gum up the cables and path to the bilge. The only issue I can potentially see is drainage, but unless I go crazy with the foam, it should not block every path and if it is full of non absorbent foam, it can't get full of water anyway. Is my logic flawed anywhere here???????
