VONCE
- Dayton, OH
Last night I decided to tackle the seasonal engine maintenance - oil change and plugs. The oil change went fairly smoothly. Replacing the filters got a little messy but that's what rags are for. Only (less than) 2 quarts of oil came out of each engine. After reading through posts, this can be normal, try parking on an incline, etc. Oh well - I am not too worried about it. I'll probably just change the oil twice a year anyway to compensate for the oil leftover in the engines.
On to the spark plugs! Oh man, these are easy to get to! This is easy! Well, the second plug from the back on the starboard engine had some better plans for me. I gapped it, smeared some anti seize on it, threaded it in by hand. Put the ratchet on the extension and snugged it up. I always hold the ratchet with one hand up pretty close to the head of the ratchet so I don't have a lot of leverage to overtighten things. This has been my tried-and-true method for 10+ years and I don't plan on changing any time soon! Well, things started getting snug, I kept going a bit because I hadn't felt the washer crush, and then everything was loose again. The ratchet spun pretty freely. Uh oh, I think I stripped it. I grumbled a bit, pulled out the plug and found this:
So I was expecting the worst. I called my mechanic friend over. He hopped up in the boat and took a look. Pulled his flashlight out and looked down in there. Asked me to hand him a magnet. He uses the magnet and pulls out the threads (that I thought and assumed were stuck in the head). I handed him a new plug and it went in and tightened down with no problem.
Still don't really understand what happened. I don't understand how those threads just hopped out of the head. I know I tightened that spark plug down. And as I was tightening is when I felt the break. So those threads should have been stuck in there. But no, they were just sitting there. Oh well! Things are well, now! And I got some more time to catch up with my friend since he didn't have as much work to do!
