JWPrendergast
- Orlando
- SS
I added a JL M600/ and a pair of Polk DB401's to the swim platform this weekend. To start, I made a mounting board and 2 mounting strips from birch. I covered them with fiberglass resin then painted em with white paint. I mounted the assembly to the helm compartment and fiber glassed it to the boat by first sanding away the manufacturers white protective coating. Once secure, I began on the Polk DB401 installation. I used a hole saw for the hole after taking VERY careful measurements, then ran the cables to the amp (the attached pictures only show the 4 speakers, not all 6... I know, I know). Im also almost finished with the HD-RLC installation which will control the attenuation of the swim platform speakers while underway.
The stock speakers sound VERY good with this amp, and will sound even better when they get replaced with the JL 7.7 speakers (in addition to adding a 2nd set to the cockpit). The Polks on the swim platform actually sound pretty good! They were, in my opinion, the best, largest speakers I could find that would work out there.
