Fixed the rotating key switch issue. 2007 - 2009 SX230, AR230, 232 Limited
Bruce
Jetboaters Fleet Admiral 1*
Staff member
Administrator
Royal, AR
I am not sure how many Yamaha models this issue exists on but on the 2007 to 2009 230/232 models the key switches are secured by a plastic nut that tightens to a curved surface. This results in slipping threads when fully tightened eventually leading to the key spinning during a start.
I 3D printed washers to separate the plastic nut from the curved surface and a locking block for the back side to securely hold the two key switches preventing them from spinning even if the nut is loose.
4C940042-34BD-4DF9-8FA8-D1BE8147596C.jpegBF041820-F11C-4207-9B7F-7205F6A09149.jpegD782FFAA-63AE-4146-8402-EB5BC6BD0FE9.jpeg57C68B9B-9AAD-4DDA-ACAC-7C3A78BC5C8E.jpeg32666251-CCDE-4345-8A87-DAF954EB04DB.jpeg
YES !!!!
I was just thinking i need somebody to figure out what size that locking nut is so i can but two and fix mine
YES !!!!
Scott, are your nuts damaged? I thought my nuts were damaged but it was just the curved surface deforming them.
I printed a test nut but have not yet determined the correct pitch. 20mm x 1mm was not right.
In my excitement to get something fixed i ran out to the boat to confirm the and...
Broke one of the threaded shafts off
The nuts are both good, i could have sworn i saw them swell and split when i tried to tighten them
Now i have to figure out how to reinstall those two small silver key pins, one is still in
911 @Beachbummer. @Betik
This drove me crazy the first few years but I didn’t want to mess with it. I’ve gotten used to it but now this makes me want to fix it. Thanks a lot. :D
cr@p. No idea, but I would guess these pieces are pins to the key? If you get the key to turn and they line up it means you put them back correctly??
Worst case perhaps an after market key might not set you back $300? Check #5 on the diagram. The key has 3 positions and each does something with the circuit. Maybe a double throw double pole switch, plus a momentary button gets you on the water this weekend.
Dual Pole Dual Throw...
Switch Off = White to Black
Switch On = Purple to R/B
Momentary button = Br to Switch on R/B above
Not sure of the color mappings on R/B. I think Br is brown. R/B maybe Red/Black?
Best of Luck!!! Minor inconvenience, I know you can make it work for the weekend!!!
Abd the remaining key pin just popped out along with it's TINY spring, don't even know where the other two tiny springs are
Looks like I'll be hoping for an after market solution, i don't see this one going back together (also the threaded shaft looks like it was molded to the switch)
Can someone please give me Dustin's contact info so i can get instructions on getting the boat started
@AnnapolisCatt :rolleyes:
@Scottintexas, do you think you can reinstall the metal pieces then glue the plastic back together?
The metal only prevents the key from turning I think. The keyway will turn without it, I'm pretty certain. (Just will turn with any key)
This seemed inexpensive compared to the options.
Time for a single key and two start buttons?
YES !!! Bummer is correct, the key does work without the pins in, only downside would be any key could start it
What do you recommend to glue the shaft back on, i don't want to screw this part up with betik in seclusion i won't have anyone to blame it on (honestly at least)
??? If you find him let me know!!!
Scott I am all purpose and situation scape goat. I am create through telepathy. :)
I am not well versed at the key system. But if Gracie needs to be in the water, I can drop the ski tomorrow.
My solution will be a a couple of switches. Kind like a push start without the need for the key.
Then I will would installed an kill switch on hard to find location that I will be only one to know.
@Scottintexas, I am having good luck with Loctite Super Glue Precision Pen for glueing plastic. I would clean with isopropyl first and allow to dry for 24 hours before reassembly.
Having the key switches on my desk I decided to check continuity.
What I found was
Switch Off - no continuity
Switch On - Red to Red Yellow
Switch Start - Red to Red Yellow and Brown
Red being the largest gauge wire I am guessing it is positive from the boat but that could be checked at the boat wiring harness.
If you are able to glue the switch back together I still would replace it to avoid failure on the water.
However it would be fun to connect the good key switch to a NO DPST relay with both pairs of red and red yellow connected to the relay then connect each red and brown pair to a push button.
If you need to start her by twisting wires together give me a call.
What I found was
Might want to be a little careful publishing this info in the open. Unscrupulous types could use this info in, uh, unscrupulous ways.
I am torn. It is useful information and would only take a few minutes to figure it out on most boats. If we want to secure our boats we really need a kill switch somewhere.
Success !!!
This is a great mod to fix that annoying problem.
I super glued that threaded shaft back onto the ignition and left the keyways out.
I did have to remove the bezel from the dash to trim about 1/4 " from the dash on the port side so the blue holder will sit flush but the bezel covers it so you don't see it
Can't wait to try it on the water
Thanks @Bruce
