BobbyP
- Glastron
- GT
Has anyone figured out how to get rid of this or a solution that has rectified it? There is no difference in performance of the boat. Everything has been cleared via Can-doo pro.
I also know that if it flashes 6 times and you recycle the ignition it will go to 3 times. It also does not stay on...just flashes on startup.
Some opinions already stated:
1. Dealer says it’s nothing.
2. Low voltage read from non seadoo dash cluster.
3. Maintenance not clerked out of computer.
Does changing the relays eliminate the flashing?
