Float Mode Water Temp:ErrF
AlphaKap
Jetboaters Commander
Alpharetta, GA
242X E-Series
My external water tempnis not showing. It says Water Temp: ErrF
I did use a boat wash recently...maybe tore up something under the water.
The depth is showing.
Any thoughts?
Any thoughts?
If you can get under the boat and examine the transducer to see if there is any debris on there or anything else that shouldn’t be on there..
And if you haven’t already turn the batteries off. If you have turned the batteries off, then disconnect the batteries for 10 mins or so then reconnect them and see what happens.
