The two most aft mats literally came off in one piece last season. My boat is vintage 2016 as well. Stored in a closed garage in winter and placed under covered wet slip for the spring / summer months. Initially, I thought the same, just re-glueing. However, upon closer inspection, the mats that had separated were brittle compared to the rest of the boat mats.
Did you re-use mats? Or decide which fix to resolve issue?
I spent nearly 6 hrs just removing the factory adhesive and roughly $45.00 on acetone, rags, nylon brushes, plastic sheets, and painters tape.
My only thought is any adhesive used in order to re-attach mats and if it does not last but for a few years would be a lot of labor for minimal return of investment. Hope you find a reasonable solution.
