DoubleThrust
- SS
I repaired the easy one or two I could barely get a nut on the back of years ago, but the rest are now becoming a full blown issue. I don't know enough about fiberglass hardware to know what the best solution is...
How do I get some kind of backer or nut on the back of fiberglass when you can't reach the back side? What comes to mind is one of these type of devices, but I'm not sure if anyone has used this type of thing successfully on the floor storage. Anyone with the older generation 21' hull should have the same floor arrangement. ------------------------------------------------------
Of course I could always just drill the hinges and put bigger fiberglass style screws in, but a properly backed and washered machine screw would make me much happier because it would be really done right...
Thoughts anyone?
Thoughts anyone?
