Yep. What he said.Engine ON then Water On to begin flush. Never run water into the engine while the engine is off or you could severely damage it (hydrolock). To stop flushing you do the opposite procedure by turning of the water first then turn off the engine last. Definitely read up on your owner's manual so you're familiar with the boat.
I run the engine until all of the salt away is gone from the cup. It will be clear then and not blue.
So do I need to flush if the boat wasn only fresh water lakes?Yep. What he said.![]()
I’m not quit sure what you mean when you say “I hook up the water turn it on it get pressure than shut off. “Good or bad? I hook up the water turn it on it get pressure than shut off. Start the engine than turn the water on. Flush than kill water, than kill engine..
