cwoav8r
- Naples, Florida
I made this adapter a while back so I can flush both engines at the same time and save a little time. I have pretty good water pressure and I flush much longer than recommended... never had an overheat issue. If I do have a pressure issue I can still use this setup and just switch from one side to the other without getting out of the boat (read lazy)... the exception of course is having to get out for another beer
Now that I am in dry storage, I hook it up before I leave the boat to make it easier for the dock hands to flush (and make sure they remember to do it.) I had to give them a lesson on flushing jetboats when I first moved it there because they were apparently not familiar with them.
Had a new dock hand cleaning my boat this past Sunday and I am lucky I forgot something in the boat. When I went back to get it, he had just hooked up the hose and started the engines... I watched for a few seconds and he did not make a move to turn on the valves.
After I showed him that they had to be turned on and, to make sure that the water was turned off before shutting the engines off all was good. I did however make the decision to leave the valves open after hooking it up to avoid this from happening again. I'll take a little salt water back in the floor to make sure that my engines get flushed, and the last thing they do is rinse the inside down anyway.
Home Depot has all the goodies to make this contraption...
