Flushing engines while in water
toddgray519
Just would like to know if you can somehow flush engines with fresh water while your boat is docked in brackish water im new could someone provide details
2023 Yamaha 222 xe
thanks
If you clamp off the inlet hose from the pump or install a shutoff valve you could flush with hose.
Just clamp off between the inlet and the flush port input
