lakesuperior
New to me 2007 AR230. I'm in Marquette Michigan.
Boat seems in great shape. I took it out briefly once and don't recall the vibration.
I did install the new version of Thrust Vectors before the second time out. Not sure if that is relevant or not.
During the second time out I noticed a fluttering vibration through the right throttle lever at higher speed. Probably 30+ MPH. It does seem to not be there at times but is usually there.
I searched through this forum before posting. I inspected the intake and impeller and did re-silicone some seems between the metal and hull. Went out again and still felt it. Last night I pulled off the jet pump and impeller and everything seemed fine. I did not open up to look at bearings but they felt very tight and smooth turning. I have not reassembled yet. The only thing I noticed was some slight damage to the impeller blades. Seems minor to me but I could be wrong.
If the impeller might not be the issue please let me know anything else I should be looking for. Thank you in advance. I'll post a pick of the boat after it gets a new wrap next week.
