Bluewater272
- Medford, NJ
- Tidewater
- Other
Hello - Quick Question. Where does the factory FM antenna interface with the stock HU? Is it a plug-in type antenna like you get with a car stereo, or is it part of the wire harness? I just finished installing two amps (one to drive in-boat speakers, one to drive towers), and I just buttoned everything up but I have no FM reception. I'll primarily be using bluetooth, but would like to get the radio working again obviously. Just looking for a little intel before I go pull the darn amp board down and try to sort it out.
Amps are wired to distribution blocks on the board, and then direct to the house battery. New wire was run to all speakers, so only tap on the factory radio harness was for remote turn on.
Thanks!
Thanks!
