Daren and Heather
- Prior Lake, MN
Is it okay to only spray fogging oil for 10 seconds in the intake to winterize? So long story but I’m in Minnesota, we get negative temps in winter, and I’m winterizing my AR210 which will be shrink wrapped and stored OUTSIDE this winter. We just got a warmup, but my sprinkler lines are already blown out.
So I only ran the engines 10 or 15 seconds, while spraying bursts of fogging oil through the intake, because I didn’t want to overheat the engines.
Do you guys think this is enough to fog the engines??? Should I be worried and redo it?
Also, afterwards I removed the spark plugs sprayed 2 seconds into each plug hole, removed the lanyard and then turned the engines over for another 2 seconds before reinstalling the plugs.
My only other option I thought of would be to buy lots of antifreeze, a pump, and pump it through the engines while I fog them longer... but I’d rather not if what I already did was sufficient.
Thanks for the help!!
