- Rosebud, Mo
- 242X E-Series
I seen castiljd post this on the other site and thought it was informative for us over here as well. Seems like the poster did a lot of leg work for us dealing with these brakes.
@Julian @Bruce
"You can buy brakes and other parts at any auto part store like autozone and get brakes for a 1997-2000 Kia Sephia. Eastern marine has the brakes for $24.99 plus shipping. I think I got the Autozone Gold DG766 for $44.99 and had to trim a little metal piece on the bottom. Wasn't that difficult. They have cheaper brakes for $23 but were semi metallic. I also think the cheaper brakes didn't have this piece. Now I have lifetime brakes for my boat. I do believe it brakes better but that could be from a lot of different things considering you have to bleed the lines and all new parts. Brakes, caliper dust boots, piston seal easily available at part stores. Found brakes at Autozone (Any part store) and dust boot and piston seal at Advance Auto Parts. Caliper dust boot and seal at Advance Auto Parts (Cheapest place) part # 15202 $4.99 or D352020 $1.99. Autozone part # 66335 $6.99 Caliper piston was hard to find so I ordered off eastern marine. The only place I could fine the caliper piston. I rebuilt both my calipers and didn't cost that much. Just time. Rebuilt both calipers in about an hour. Some rather just buy a new caliper. To rebuild here is what you will need. You might not need all of this. My caliper piston was pitted and rusted due to dust boot being tore. So I had to get a new piston. All these parts listed below for rebuild is less than $21 plus shipping. For me s/h was like $15. So about $36 to rebuild caliper which doesn't take that long. I did both of mine and was less than $60 with shipping. Parts list from Eastern Marine. If you only need dust boot and seal go to auto part store. Order a couple extra dust boots if ordering online. They can tear pretty easy.
UFP DB-35 Disc Brake Caliper Piston #33005
UFP DB-35 Disc Brake Caliper Piston #33005 - Stock #: 5415073
Edit $11.99 $11.99
Remove item
UFP DB-35 Disc Brake Caliper Piston Dust Boot #33307
UFP DB-35 Disc Brake Caliper Piston Dust Boot #33307 - Stock #: 5415102
Edit $1.19 $1.19
Remove item
UFP DB-35 Disc Brake Caliper Piston Seal #33004
UFP DB-35 Disc Brake Caliper Piston Seal #33004 - Stock #: 5415072
Edit $0.75 $0.75
Remove item
UFP DB-35 Disc Brake Caliper Slider Pin #33007
UFP DB-35 Disc Brake Caliper Slider Pin #33007 - Stock #: 5415074
Edit $2.25 $4.50
Remove item
UFP DB-35 Disc Brake Caliper Slider Pin Boot #33305
UFP DB-35 Disc Brake Caliper Slider Pin Boot #33305 - Stock #: 5415107
Edit $0.75 $1.50
Remove item
UFP DB-35 Disc Brake Caliper Slider Pin Boot Plug #33306
UFP DB-35 Disc Brake Caliper Slider Pin Boot Plug #33306 - Stock #: 5415108
Edit $0.50 $1.00 "
@Julian @Bruce
Edit $11.99 $11.99
Remove item
Edit $1.19 $1.19
Remove item
Edit $0.75 $0.75
Remove item
Edit $2.25 $4.50
Remove item
Edit $0.75 $1.50
Remove item
Edit $0.50 $1.00 "
