Craigz
- Other
- NA
- Other
- Other
Hey everyone
Just a couple quick questions this time.
Is there anything I should be doing for maintenance of the fresh water such as dump and refill, chemicals, etc?
Also is it possible/practical to add the pump out toilet aftermarket? Is it just a different toilet or does it actually have a pump out port on the side of the boat?
Also after my recent issue with taking on water I want to install a backup bilge pump with a much high capacity. Is there a size of bilge pump that would run on the boat without electrical overload and be able to keep up in case of a carbon seal failure or another major issue?
I basically want a pump and an emergency light/siren on the dash that's above the factory one and will warn me to head to shore asap and keep the water low enough that the engines don't cut out.
