Adrian @ JB Solutions
- Tampa Bay, FL
- 252SE
Well what started as hmm that’s weird turned into a full day ordeal.
I noticed the lights on my 24v trolling motor were not visible and read a cause could be low voltage. Checked voltage and sure enough 16v. Time to move to the batteries…. Haven’t plugged them in a week or two so let’s just charge them up. Battery 1 gives a connection error. Wires from charger look good, so to more reading. That error can occur when voltage is too low. Test the battery and get 4v. Look at date on battery and it’s from 2013!
Now a quick trip to Walmart for a replacement and wire everything up. As I’m wiring back up I notice the wire to connect the two batteries in series is rusted. I check for continuity between the ends of the cable and get nothing at all. Not even sure how the trolling motor was still working. I grabbed some old 4 gauge wire from the attic and made a new cable, hook everything back up, test one final time and viola 25v and battery meter on motor is working again.
Now this has m thinking because my house battery has been reading low even after charging and replacing it. So I decide to inspect everything by house and start batteries. House isn’t too bad wire wise but starting wire is showing 7 ohms resistance and can hardly register continuity. I pull off the DSVR and find a ton of corrosion. There was mild corrosion around other battery cables as well. I took everything apart, cleaned it up, new cables, and corrosion spray everywhere.
I suspected some sort of battery drain for the house, so I ordered some distribution blocks just to make sure it’s truly shutting off. Hopefully will have this all finished up tomorrow.
![0BBC933A-0FCC-4A36-9566-D3A4674F3248.jpeg 0BBC933A-0FCC-4A36-9566-D3A4674F3248.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/194/194306-9e9ed55cf820feb77a41f9170061140a.jpg?hash=np7VXPgg_r)
![9E60A609-7619-4D47-8B22-C0CAF9B6C9E1.jpeg 9E60A609-7619-4D47-8B22-C0CAF9B6C9E1.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/194/194308-fada6a51278213c8828df33ed87d47c0.jpg?hash=-tpqUSeCE8)
![0AF5C028-9DBE-4BE9-932F-DD7688CCF7D9.jpeg 0AF5C028-9DBE-4BE9-932F-DD7688CCF7D9.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/194/194309-1d64e16ad6c40a04f601b7c99d91a5b1.jpg?hash=HWThatbECg)
