Jonyreb
- FSH Sport
My front hatch isn’t draining properly around the lid. Water just sits there and will start molding if I don’t remove it. The line is not clogged because under pressure it drains perfectly but natural gravity it just stands. I currently had to pull the drain connection out and let it drain directly into the front cargo space. I’m thinking there is a belly somewhere in the drain line but haven’t found it. Any ideas or help would be appreciated
