Billy Marlin
- Tallahassee, FL
- FSH Deluxe
Grease here after pulling the cap I put about 20 pumps in the same on both of my rim hubs.
Remove the 2 bolts holding the engine cover
Under the cover remove the bolts with 10mm nut driver holding the boots to the spark plugs.
Using a 5/8 spark plug socket loosen the spark plugs, then use a magnet to pull them and for putting them back in
Look good and dry no oil or residue just a little black but normal
Mighty vac this thing is AWESOME just select the size tube to go down the dip stick tube give the handle a couple of pumps and it starts pulling the oil pretty fast. Make sure and warm up the engine for about 10 minutes so the oil will pump through easy.
Got 3.4 Liters of oil out
Using a plastic bag and duck tape under the filter to catch any oil that spills out removing the filter.
Another view of plastic bag to catch oil
Put new oil back in and hooked up the water
Made sure I have good drainage
