Fuel leak
Scott griffith
Pensacola fl.
SR
Hey everybody need a little help I have a leak around the rim of the fuel sending unit . What is the best way to fix thank for the help
Do you have the original fuel sending unit and does it read properly? If it doesn't read well, you might want to just get a new sender and it will come with a new gasket....
Yes I have to original unit and it only leaks when it is full and it reads right
O ok thanks just so I'm make sure your talking about the right part . Is it part number 28 on the diagram you sent me
Not to be rude but make sure you install in the correct orientation as it only goes one way. My 08 was leaking at gasket because it was installed wrong. I spun it one bolt pattern to the right and it aligned correctly.
