Fuse and Radio Amp Issue 242X
ToddW850
Destin, Florida
242X E-Series
2017 Yamaha 242X E -Series
Blew a fuse for the Solar Panel. Before I tracked down the fuse , I noticed only the front 2 bow speakers were working and only 1 Polk Amp has power. Replaced the Solar Panel fuse and all the speakers are working now except the swim platform and the ones attached to the tower.
Amp still not coming on. I checked the fuses on the side of the amp and they are good. Any ideas what to check next?
Check the remote wire for the amp. Could be a loose connection.
Thanks. I touched and moved the wires, but I will go back and check them better.
Did you find out what was causing this? Same issue, top Polk amp shows no power and tower canon speakers not working. Everything else seems to work. Thx.
