Fuse for freshwater shower
Michael Guzzo
Tampa Fl.
Can anyone tell me where this is? My shower quit working a couple weekends back and I am just now able to get back at it.
Thanks!
Shouldn't it be a breaker under switch to turn on?
There is a breaker under the switch that looks like a button. They are notorious for crapping out. Start checking there.
How would I know if that breaker was bad? When I feel it all I can feel is the rubber cover, no button or switch sticking out underneath. It actually feels exactly like all the others.
In the owners manual it shows 2 fuses in the battery compartment near the 3 knobs to turn battery power on off. It lists them as main accessory power, yellow, 20 AMP and shower pump, pink, 4 AMP. However all I see there is a single 30 AMP fuse. Go figure.
Do you have a picture of the battery area maybe we can spot it or help you. Also you would need a volt meter to check the breaker to see if it working I do not have a fresh water shower on your boat so my help is limited.
