Can anyone tell me in detail how to connect bluetooth to a fusion ms-ra205?, I went into accessories click bluetooth and nothing connects. Thanks in Advance.
See here from the manual. Make sure you don't have another device with bluetooth on that is connected to it. We went through this last night as my daughter's phone was connected. Make sure it is set to broadcast so you can see it in your phone's bluetooth devices.Also you can forget the device if it shows up and doesn't connect to make it go through the find/connect process again.
BLUETOOTH SETTINGSTo change a setting in the Bluetooth settings menu:1. Press the Menu key while the BT Source screen is displayed. 2. Turn and then press the Rotary Encoder to select one of the following; • List of Paired Bluetooth media devices. To connect to an active device on the Paired Devices list rotate the rotary encoder to select the device. Press the rotary encoder to select the check box.The device must be turned on, with Bluetooth on and not connected to another Bluetooth device, otherwise it will not connect.DISCOVERABLE Enable this option to make the MS-BT200 Bluetooth module discoverable to Bluetooth media devices. Press the encoder to select/deselect the check box.
