Fusion - SXV300 XM Tuner - Terk XMarine: Issues
KKVAD
242 Limited S E-Series
Hi there!
I installed an SXV300 XM Tuner with a Terk XMarine antenna this weekend into my Fusion MS-RA70NSX radio. Initially it worked great, however every time I shut the boat off (at the battery), then turn the boat back on, the only sound I get is a dull noise from the subwoofer. I have to disconnect and reconnect the Terk antenna for sound to play again. Works fine after that, just as long as I don't turn off the battery. Kind of a pain.
While the issue is happening, meaning that dull subwoofer sound, I can switch from other "sources" (i.e. FM/AM/Blue Tooth) and everything sounds fine other than the XM source. Also, the Fusion app seems to be working great as well.
Any ideas?
